SailNet Community - View Single Post - Sealing the inside of mast
post #9 of Old 09-23-2008 Thread Starter
wstigg
To knothead Steve -
Hi Steve - Heaps o thanks for getting back to me re: sealing the inside of my Selden spar. The mast came with a fitted foam chunk about deck level but I had to remove it to install an inside headstay fitting that needed to go up the inside of the mast. This block may have been dam. Nuts. Next time I pull the rig, I'll follow your proceedure. Until then, I'll seal the very foot of the mast from the outside and drill a small drain hole and hose to drain down into a catch bucket. This should do just fine. Many thanks again
wstigg is offline
