Originally Posted by Giulietta
Keel, I am not going to argue this anymore.
Was not trying to argue anything Giu; I was simply trying to add some information to your excellent post of how to adjust your rig tension.
Since there was confusion on what your post was saying I tried to determine why it would be 1mm extension for 1 meter or 2 meters; but it is off by ~50%. The calculation is correct; so it must be a problem with the published breaking strengths. So I was doing some more research on 316 stainless and it turns out that the published breaking strengths must not be actual ultimate breaking loads; they seem to have a safety factor of 2 built in. The 15% breaking strength calculations I did earlier were based on the published breaking loads; while the Selden formula is based on the true Utimate Tensile Strength of stainless wire (actual failure strength).
