SailNet Community - View Single Post - Ground leak?
Thread: Ground leak?
Old 09-23-2008
ckgreenman's Avatar
ckgreenman ckgreenman is offline
AFOC Stinkus Potus
ckgreenman will become famous soon enough
Send a message via AIM to ckgreenman Send a message via MSN to ckgreenman Send a message via Yahoo to ckgreenman
If it is something like the memory line to a stereo, it might have a capacitor on it...and that might account for the higher initial draw...while the cap is charging, and then the steady state of 2mA is what it draws after the cap is finished charging.
BTW, it might not be wired to the positive battery terminal, but to the battery switch or some other place you'd have an always hot 12 VDC connection.
If you don't have any wires that could be such a leak... then you're up to checking the Ground Leak, which is the second section of that post.
I was just gonna say that it sounds like a capacitor charging up. Check everything possible.
You might also try pulling the fuses one at a time until it stops. that would at least give you somewhere to start tracing it out.
Chris
S/V "The Jade Dragon"
1975 O'Day 25
Meet me at
Ignore Power = Currently Rebuilding
