SailNet Community - View Single Post - Winterizing For Cold Weather
post #9 of Old 01-14-2004
another easy solution is to put a "Y" in your water intake hose, (above the thru hull shutoff), with a short hose on the new intake. After starting the engine, stick the hose in a gallon of Marine antifreeze, throw the valve, and suck the a/f till you see pink from the exhaust, then shut down the engine. A 2 minute job!
ross99 is offline
