SailNet Community - View Single Post - What to do next on my project boat?
post #4 of Old 09-26-2008
sailingdog
I'd highly recommend you work from the inside out... as you're doing the interior the chances of making the exterior a bit worse is pretty high, so you'll want to do the exterior painting—hull, deck, bottom—last.
Remove as much of the deck hardware as you can, and leave it off until you paint the deck. The paint job will be easier and last longer if you remove the deck hardware.
Just remember, preparation is 95% of the work in a good paint job, and most paint jobs succeed or fail based on the prepwork done.
sailingdog is offline
