Old 09-30-2008
sailingdog sailingdog is offline
It depends on where the turning blocks for the halyards being led aft are located. IF they're attached to the mast foot, having the exit slot just above them would make sense. If they're mounted on the cabin top, you probably want the exit slots a bit higher up so the line leads fair to the blocks.
Originally Posted by wchevron View Post
i'm thinking of running my main halyard internally in my mast. currently the external halyard is raised with a winch located on the mast. if i run the halyard internally, about how far off the deck should i exit the mast. i'm going to run the halyard back to a new winch located on the cabintop near the cockpit and abandon the winch on the mast.
