Exiting at least 5-6 feet above deck can be very helpful in allowing a person at the mast to raise the sail quickly.(as Nola has already noted) Even though you may be doing this so that you can do it all from the cockpit, grinding a halyard up from under a dodger can be a slow arduous process. The same sail can be raised in seconds with a jumper (again, Nola has already noted this.)
As to putting a winch on the mainsheet - with a mid boom arrangement I don't see how you can avoid it and still be able to properly sheet the sail in.. but personally I abhor mid boom sheeting setups, esp if they are ahead of the companionway (I realize there are other advantages, but don't think the tradeoffs are worth it) - JMO
1984 Fast/Nicholson 345
