Old 01-28-2004
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Moderator
Jeff_H will become famous soon enough
preperations for offshore sailing
Adding to the list,
Make sure your reefing works easily and that you are familiar with how it works by actually using it. I like to mark the main halyard with a stitched on whipping so I can find it in the dark at each reef point so I quickly know how far to ease the halyard for each reef.
Make sure that the boat can be made as watertight as possible. If you get pasted the movement of the boat and the force of wave action will force water into places that do not normally leak. Make sure that hatches are properly gasketed and can be dogged down, including your lazarette and sail lockers. On a small boat like your Lancer it probably makes sense to remove ventilators (except where you have fuel stored)and seal the openings.
Add solid mounting points for a jackline either side of the boat and a low stretch jackline either side plus a solid mounting point at the companionway to clip on before coming on deck. Id you don''t have one get a good harness with two teathers or one of the new delayed inflate harness/lifejackets.
Add hold downs for all locker lids and heavy objects such as tanks, canned goods, the stove and the battery banks.
Repair kits for the essential systems. Think about how you would jury rig a rudder should yours fail.
Make sure that your bow cleat is of adequate size and properly backed up if you needed to take a tow or anchor on a leeshore in heavy conditions. Make sure that you have easy to deploy chafe gear aboard.
Before you leave the dock set aside high energy foods in easy places to reach that are easy to digest and which can be eaten as that are.
Before leaving the dock think through contingency plans if you can''t get to where you originally planned to go. Put the waypoints in your GPS and plot courses on the chart for your primary destination and these back-ups.
Do not set a fixed schedule or feel you have to do something just because you had planned to (except for having a good time). Let the weather and your physical condition dictate your time table. Don''t be afraid to head back it if things are dicier than you would like. You have nothing to prove by being overly heroic.
And Jim thanks for you very kind words on the other thread. I think the quote about the pig was an Abe Lincoln line and it actually went something like "Never try to beat a pig at wrestling because you will only end up rolling in the slop and only the pig enjoys doing that." I am feeling like I have been dragged through the slop on that tar baby of a thread. ;^)
Best wishes,
Sponsored Ad
