BILGE PUMPS
If your bilge is too shallow to accommodate a conventional submersible impeller type (centrifugal) bilge pump, you can install a self-priming diaphragm pump. The diaphragm pump is conveniently mounted out of the bilge, with only the pick-up (inlet) hose & strainer in the bilge. Alternatively, you could install a manual pump in the cockpit (pick-up is also in the bilge).
Regards,
Gord
