SailNet Community - View Single Post - Topping lift
Thread: Topping lift
post #9 of Old 01-31-2004
Jeff_H
Moderator
Jeff_H's Avatar
Topping lift
I would agree with you in many cases but I believe that the boat in question is a Hunter 26 which is probably a bad choice to use a topping lift to support the boom when sailing. I also somewhat disagree with the idea of using a rigid vang to support the boom instead of a topping lift on a boat this size. In order to support a small boom on a rigid vang there needs to be a lot of upward pressure preset on the rigid vang and so you are constantly having to adjust the vang or use excessive mainsheet pressure to over come that tendancy for the boom to lift. It really makes very little sense.
Jeff_H is offline
