SailNet Community - View Single Post - Rail Mounted Propane?
Old 10-06-2008
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Moderator
If the tanks are going to be exposed to a lot of sea water, it would probably be best if you used COMPOSITE tanks. The fiberglass tanks won't rust or corrode, like aluminum or steel tanks.
I wonder about UV, though.
Although I'd worry more about the propane lines and UV. It would be good to sleeve them with some material (hollow dacron webbing?)
Faster's tanks look better than the ones we have for our home BBQ...
