Originally Posted by blt2ski
OK, now that I look at that chart for the umteenth time, I am seeing that I need to convert pitch inches, to pitch degrees! so need to be at 16* if I use the fixed 13x7 blade that came on the boat, and use the 13" two blade that is on it. Now to go look up and see if this is what I am at, or if it might be incorrect for what I have for a motor, trans gear etc.
hmmmmmmmmmmmm
Call them - they'll type in your boat make / model / yr / engine and give you what you need to have it set at.
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
