On deck, you can build a small dam out of modeling clay or beeswax (sold cheaply as toilet bowl ring seals) so the water will not run into your work area, then just arrange something over that so rain can't fall directly in it. An alcohol wash (isopropanol) should remove any surface moisture from the working surfaces.
