  #32 (permalink)
Old 10-08-2008
Maine Sail's Avatar
Maine Sail Maine Sail is offline
Originally Posted by poopdeckpappy View Post
First I need to correct what I said, I said it was not very flexible when I meant to say it is very flexible
Second
I made no such error
Sorry thought you did and with the bad "shoot from the hip" info thrown around these days I wrongly assumed. My bad and I own it!!
Generally ?? maybe, but not 100% true, what I was referring to was a polysulfide adhesive/sealant that is very flexible and dose have a bonding strength of 1000psi ( yes, over kill, but none the less ) and it is safe to use with most plastics, ( Synthetic glass & PVC don't fall into the compatible materials) but is compatible with most all other Plastics found on a boat ( ABS,Epoxy, Nylon, etc: )
yes there is and yes it is commercially available,
I would really appreciate it if you could steer us all to a more highly adhesive polysulfide suitable for use in the marine environment that is also bellow waterline rated and has 1000 PSI adhesion?
I think many would be interested in this product!
You know the original author of this topic said nothing about bedding plastic,
I am fully aware of that! I mentioned after dog to reiterate a good point. I've worked in three different boat yards and have seen MANY products from portlights to inclinometers ruined by Life-Caulk/Polysulfide. I love polysulfide it is my sealant of choice next to butyl but you need to understand when and whre to use it that's all.
that is, like I said, his boat was built by Revell and his Chain plates and stanchions are made of Lexan,Plexi or PVC, So the 'suggestion' of BoatLife Lifecaulk was a good suggestion, as were all the others.
Yes Life-Calk or 3M 101 would both eb great choices..
Bottom line is know your material and know your product
Oh and your list of caulking products is short by several thousand adhesive/sealant products
I do know my sealants fairly well, at least the marine rated ones. No commercial boat yard I have ever worked in would ever consider using a non marine or non-bellow waterline rated product. While there may be better products out there the insurace companies would have a field day if a boat sunk because a boat yard used a construction trade sealant not specifically rated so they usually don't.
Of course my list is short and I tried to keep it succinct to what you may find in a marine chandlery . I did not mention any of the boat builder/ marine trade specific stuff such as Plexus because they are hard to find and especially in small volumes & no one on this forum wants to buy a 55 gallon drum..
Sorry for thinking you were confusing polysulfides with polyurethanes! We would all like to know about this commercially available 1000 PSI polysulfide product..?
______
-Maine Sail / CS-36T
