SailNet Community - View Single Post - Mast length
Thread: Mast length
post #3 of Old 10-08-2008 Thread Starter
runner
Sailrite shows the original main as 14.33 feet by 7.5 feet. The sail being used on the mast was a 15 footer, but on the smaller boat it would be more like 16 x 7.5. The original setup was holding the boom above the slot by the luff rope. 14.33 times 7.5 versus 16 x 7.5 and the heavier mast. The Jib shows as a touch smaller than the one with the mast, but not much. Using the shorter boom we are talking 65 or so on the main and 30+ on the jib. Right at 100 sqare feet on a 12.5 foot boat. The original sails show about the same for the standard main and genoa combination. The main and the Spinnaker would be 150 or so.
How much difference does a few more pounds on the mast make?
Does anyone know what the length of the original mast on these boats was?
The foot is a sit over type with a small hook and bolt. The mast uses a heavy center pin from the side. I can mill a bracket to change it over. I just don't want to set up a boat that falls over for the slightest excuse.
runner is offline
