SailNet Community - View Single Post - How to spruce up molded in non-skid deck???
post #12 of Old 10-13-2008
sailboy21
sailboy21's Avatar
Originally Posted by Banshi View Post
I painted mine and I did not have any problems with "pooling" paint. I used interdex nonskid and put it on with a roller cutting in at the edges where the color changed with a brush. If the paint is pooling your putting to much on at a time. It took two coats on mine. The moulded non skid areas a giege and the flat areas ( I used non skid paint in these areas as well) are white. This is probably the best picture I have.........but you can clearly see the moulded non skid is still there and the deck is far grippier now...........
Good job. Another satisfied Interdex user.. Did you sand your deck at all? I pretty much annihilated by molded non-skid, but that was only to removed the last guys paint attempt. It says it sticks to properly de-greased gel-coat. I would bet Banshi here used a drill attachment paint mixer. I did a couple small sections hand stirring that looked like crap. Stir stir stir!!!
sailboy21 is offline
