It is simple!!
The anti-siphon valve goes between the outlet from the pump to the bowl.
You simply remove the little white factory hose that runs from the pump around the back of the toilet to feed and fill the bowl. Run your new hose from the pump to a nice high anti-siphon breaker and then back to the inlet to the bowl..
It does not go on the intake to the pump but rather the outlet of the pump and then you can't siphon water but can still prime your pump...
Here is the exact wording from the Raritan PH-II manual pg. 5:
WARNING: Below waterline installations
require vented loops. Top of the loop must
be above waterline at greatest angle of heel.
Intake vented loops must be installed
between pump and back of the bowl.
______
-Maine Sail / CS-36T
