SailNet Community - View Single Post - James Baldwin's Pocket Bluewater Cruising Boat List
Old 10-18-2008
sailingdog sailingdog is offline
There are often people looking to get a bluewater capable boat for a relatively low budget. James Baldwin, of Atom fame, has posted a list of about sixty boats that are under 33' which he considers fairly capable and easily modified to be used as bluewater pocket cruisers. I'm pretty impressed with the list, but it is limited to monohulls. Many of these boats are available for under $30,000. If you don't require a 40'+ monster and can deal with the limitations of a smaller boat.... your dream boat may be on this list.
You can read the list here.
I've also copied the boat names and specifications, but not his entire article here for your consideration. James has commented on most of the boats and listed some of the pluses and minuses of them.
Falmouth Cutter 22 - LOA: 30’6” LOD: 22’ LWL: 20’10” Beam: 8’ Draft: 3’6” Displacement: 7,400 lbs. Ballast: 2,500 lbs encapsulated lead.
More info: The Falmouth Cutter Web Site
http://www.samlmorse.com/?a=fc_home
Cape George Cutters § Falmouth Cutter 22' § Cecil Lange / William Atkin / traditional full keel sailboat
Bristol 24 - LOD: 24’7” LWL: 18’1” Beam: 8’ Draft: 3’5” Displacement: 5,920 lbs. Ballast: 2,400 lbs? Sail Area: 296 sq. ft.
More info: Bristol Owners' Association Home Page
Pacific Seacraft Dana 24 - LOA: 27’3” LOD: 24’ LWL: 21’5” Beam: 8’7” Draft: 3’10” Displacement: 8,000 lbs. Ballast: 3,200 lbs. internal lead.
Bayfield 25 - LOD: 25’ LWL: 19'8" Beam: 8' Displacement: 4,300 lbs Draft: 2'11" Ballast: 1,500 lbs.
Cape Dory 25 - LOD: 24’10” LWL: 18’ Beam: 7’3” Draft: 3’ Displacement: 4,000 lbs. Ballast: 1,700 lbs. Sail area: 264 sq. ft.
Cape Dory 25D - LOD: 25’ LWL: 19’ Beam: 8’ Draft: 3’6” Displacement: 5,120 lbs. Ballast: 2,050 lbs.
Pacific Seacraft 25 – LOA: 26’3”? LOD: 25’ LWL: 21’ Beam: 8’ Draft: 3’4” Displacement: 5,700 lbs. or 4,750? Ballast: 1,300 or 1,750? internal lead.
Rhodes Meridian 25 - LOA: 24’9” LWL: 17’6” Beam: 7’ to 7’3” Draft: 3’3” to 3’7” Displacement: 5,000 lbs. Ballast: 2,750 lbs.
More info: Meridian
Contessa 26 / Taylor 26 - LOD: 25’6” LWL: 21’ Beam: 7’6” Draft: 4’ Displacement: 5,400 lbs. Ballast:
Cape Dory 26 - LOD: 25’11” LWL: 19’3” Beam: 8’ Draft: 3’7” Displacement: 5,300 lbs. Ballast: 2,400 lbs. Sail area: 304 sq. ft.
Cheoy Lee Offshore 26 - LOD: 25’7” LWL: 20’11” Beam: 8’10” Draft: 3’9” Displacement: 6,100 lbs. Ballast: 2,240 lbs.
More info: Offshore 26
International Folkboat 26 - LOD: 25’8” LWL: 19’7” Beam: 7’5” Draft: 4’ Displacement: approx. 5,000 lbs. Ballast: 2,750 lbs.
Kaiser 26 - LOA: 27’6” LOD: 26’ LWL: Beam: 7’10” Draft: 4’ Displacement: 6,200 lbs. Ballast: 2,700 lbs.
Morris Frances 26 - LOD: 26’ LWL: 21’3” Beam: 8’ to 8’2” Draft: 3’10” Displacement: 6,800 lbs. Ballast: 3,500 lbs. (external or encapsulated lead)
More info: Sailboat - Frances 26 by Morris Yachts and Victoria Yachts designed by Chuck Paine
Pearson Ariel 26 – LOD: 25’7” LWL: 18’8” Beam: 8’ Draft: 3’8” Displacement: 5,120 lbs. Ballast: 2,300 lbs. lead.
More info: Ariel Home Page
Westerly Centaur 26 - LOD: 26’ LWL: 21’4” Beam: 8’5” Draft: 3’ Displacement: 5,500 lbs. Ballast: cast iron.
More info: SCA - THE TRUTH ABOUT TWINS
BoatUS.com: Boat Reviews by Jack Hornor, N.A. - Westerly Centaur 26
Albin Vega 27 - LOD: 27’1” LWL: 23’2” Beam: 8’1” Draft: 3’10” Displacement: 5,070 lbs. Ballast: 2,020 lbs.
More info: The Albin Vega
Bristol 27 - LOD: 27’2” LWL: 19’9” Beam: 8’ Draft: 4’ Displacement: 6,600 lbs. Ballast: 2,575 lbs. internal lead.
Sailing Magazine
Cape Dory 27 - LOD: 27’1” LWL: 20’ Beam: 8’6” Draft: 4’ Displacement: 7,500 lbs. Ballast: 3,000 lbs. Sail area: 365 sq. ft. General Comments: Alberg design. 227 built between 1976-84. More info: CDSOA, Inc. -- CD27
Cheoy Lee Newell Cadet / Offshore 27 - LOD: 26’10” LWL: 19’6” Beam: 7’8” Draft: 4’4” Displacement: 6,900 lbs. Ballast: 2,700 lbs. (iron in cement) General Comments: At least two versions were built in the 1960’s at the Honk Kong yard. Minuses: Teak decks from the 1960’s are a maintenance problem. More info: Cheoy Lee Cadets
Dockrell 27 - LOD: 27’ LWL: 21’ Beam: 8’ Draft: 3’ Displacement: 7,000 lbs. Ballast: 3,200 lbs. long iron wing keel.
More info: Dockrell 27 cutter archive details - Yachtsnet Ltd. online UK yacht brokers - yacht brokerage and boat sales
Pacific Seacraft Orion 27 - LOA: 30’ LOD: 27’ LWL: 22’2” Beam: 9’3” Draft: 4’ Displacement: 10,000 lbs. Ballast: 3,800 lbs.
Nor’Sea 27 - LOA: 31’ LOD: 27’ LWL: 25’ Beam: 8’ Draft: 3’10” Displacement: 8,100 lbs. Ballast: 3,100 lbs.
More info: Nor'Sea 27
Sailing Magazine
Sea Sprite 27/28 - LOD: 27’11” LWL: 20’ Beam: 8’10” Draft: 4’3” Displacement: 7,600 lbs. Ballast: 3,600 lbs.
More info: Sea Sprites: Home
Tartan 27 - LOD: 27’ LWL: 21’4” Beam: 8’8” Draft: 3’2” with board up, 6’4” board down. Displacement: 7,400 lbs. Ballast: 2,400 lbs.
More info: Welcome to the Tartan Owners website
Vancouver 27/28 - LOD: 27’ LWL: 22’11” Beam: 8’8” Draft: 4’3” Displacement: 8,800 - 8,960 lbs. Ballast: 3,500 lbs.
More info: Boats.com - Boat Review/Test: Pocket Voyager
Bristol Channel Cutter 28 - LOA: 37’9” LOD: 28’1” LWL: 26’3” Beam: 10’1” Draft: 4’10” Displacement: 14,000 lbs. Ballast: 4,600 lbs.
More info: Boats.com - News: Hess's Bristol Channel Cutter
Cape George Cutters § Bristol Channel Cutter 28' § Cecil Lange / William Atkin / traditional full keel sailboat
Cape Dory 28 - LOD: 28’1” LWL: 22’2” Beam: 8’10” Draft: 4’ Displacement: 9,000 lbs. Ballast: 3,500 lbs. Sail area: 404 sq. ft.
More info: CDSOA, Inc. -- CD28
Cheoy Lee Offshore 28 - LOA: 28’ LWL: 22’ Beam: 9’2” Draft: 3’6” with centerboard up. Displacement: 8,000 lbs. Ballast: ?
Great Dane 28 - LOA: 28’ LWL: ? Beam: ? Draft: ? Displacement: ? Ballast: ?
L. Francis Herreshoff H-28 - LOA: 29’6” LWL: 23’ Beam: 8’10” Draft: 3’11” Displacement: 7,300 lbs. Ballast: 3,950 lbs.
More info: Compass Yachts
Liberty Yachts Custom 28 - LOD: 28’ LWL: 24’ Beam: 9’6” Draft: 4’ Displacement: 12,000 lbs. Ballast: 5,000 lbs.
Morris Linda 28 - LOA: 28’1” LWL: 23’4” Beam: 9’2” Draft: 4’4” Displacement: 8,300 lbs. Ballast: 3,900 lbs lead.
Pearson Triton 28 - LOD: 28’6” LWL: 20’6” Beam: 8’3” Draft: 4’ (later models 4’3”) Displacement: approx. 8,000 lbs. Ballast: 3,019 lbs. (early models before hull #383 external lead, later models internal lead.)
More info: New England Triton Association
Rhodes Ranger 28 - LOA: 28’6" LWL: 20' Beam: 8' Draft: 3’10” Displacement: ? Ballast: reported as 1,900 lbs. external iron or 2,750 lbs. lead.
More info: Philip Rhodes Sail Boats
http://astro.temple.edu/~bstavis/pr/ranger-accomodations.jpg
Shannon 28 - LOD: 28’2” LWL: 22’11”’ Beam: 9’6” Draft: 4’3” Displacement: 9,300 lbs. Ballast: 3,600 lbs. lead.
Southern Cross 28 - LOA: 30’5” LOD: 28’ LWL: 20’2” Beam: 8’6” Draft: 4’8” Displacement: 8,500 lbs. Ballast: 3,400 lbs.
More info: member info
Taipan 28 - LOA: 28’ LWL: about 22’ Beam: about 8’ Draft: 4’6” Displacement: 7,850 lbs. Ballast: 3,085 lbs. More info: Atom Voyages | Islander Taipan 28 Refit Photos
Westsail 28 - LOD: 28’ LWL: 25’ Beam: 9’7” Draft: 4’4” Displacement: 13,500 lbs. Ballast: 4,200 lbs.
More info: WOA Web Site
Alberg 29 – LOD: 29'3" LWL: 22'3" Beam: 9'2" Draft: 4'7" Displacement: 9,000 lbs. Ballast: 4,000 lbs. Sail area: 416 sq. ft.
More info: Twentynine » An Alberg 29 Site
Bayfield 29 - LOA: 29’ LOD: about 27’6” LWL: 21’9” Beam: 10’2” Draft: 3’6” Displacement: 7,100 lbs. Ballast: 3,000 lbs.
More info: Bayfield 29 - Used Sailboat Market in Canada
Bristol 29 - LOD: 29’2” LWL: 22’8” Beam: 9’2” Draft: 4’6” Displacement: 8,400 lbs. Ballast: 3,350 lbs. internal lead. Sail area: 402 sq. ft.
Islander 29 - LOA: 29' LWL: 20'4" Beam: 8'11"' Draft: 3'8" Displacement: 8,100 lbs. Ballast: ?
Westerly Konsort 29 - LOA: LOD: 28’10” LWL: 25’7” Beam: 10’9” Draft: 3’3” Displacement: 9,211 lbs. Ballast:
Alberg 30 - LOA: 30’3” LOD: 30’3” LWL: Beam: 8’9” Draft: 4’3” Displacement: 9,000 lbs. Ballast: 3,300 lbs. (encapsulated cast iron) Sail area: 410 sq. ft.
More info: The Alberg 30 Site
Sailing Magazine
Allied Seawind Ketch 30 - LOA: 30’6” LWL: 24’ Beam: 9’3” Draft: 4’3” Displacement: 12,080 lbs. Ballast: Sail area: 500 sq. ft.
Bristol 30 - LOA: 30’ LWL: 22’8” Beam: 9’2” Draft: 4’6” std. keel. (centerboard version 3’4”) Displacement: 8,400 lbs. Ballast: 3,450 lbs. (internal lead) Sail area: 402 sq. ft.
Cal 30 - LOA: 30' LWL: ? Beam: 10' Draft: 4'11" Displacement: ? Ballast: ?
Cape Dory 30 - LOA: 30 2" LWL: 22'10" Beam: 9' Draft: 4'2" Displacement: 10,000 lbs. Ballast: 4,000 lbs. Sail area: 437 sq. ft. cutter.
More info: CDSOA, Inc. -- CD30
Cheoy Lee Bermuda 30 - LOA: 29'7" LWL: 24' Beam: 8'9" Draft: 3'8" Displacement: 10,100 lbs. Ballast: Sail Area: 343 sq. ft. General Comments: Available as ketch or sloop. Built in Hong Kong from 1962-67 in wood and fiberglass. Minuses: Lots of wood to maintain even on the fiberglass version. More info:
Cheoy Lee Bermudas
Cheoy Lee Luders 30 – LOA: 29'10" LWL: 22' Beam: 9'1" Draft: 4'9" Displacement: 9,900 lbs. Ballast: 3,750 lbs. Sail area: 425 sq. ft.
More info: Luders 30 - Cheoy Lee
Rawson 30 - LOA: 32'6" LOD: 30'6" LWL: 22' Beam: 9' Draft: 5' Displacement: 12,500 lbs. Ballast: 5,000 lbs. Sail area: 565 sq.ft. General Comments: William Garden design.
Cape George 31 - LOA: 36' LOD: 31' LWL: 27'6" Beam: 9'6" Draft: 4'6" Displacement: 15,835 lbs. Ballast: 7,200 lbs. internal lead.
More info: Cape George Cutters § History § Cecil Lange / William Atkin / traditional full keel sailboat
Cheoy Lee Offshore 31 - LOA: 30'9" LWL: 23'4" Beam: 8'10" Draft: 3'10" Displacement: 10,750 lbs. Ballast: 4,000 lbs. Sail area: 424 sq. ft.
More info: Offshore 31
Nicholson 31 - LOA: 31’7” LWL: 24’2” Beam: 10’3” Draft: 5’ Displacement: 14,750 lbs. Ballast: 5,300 lbs. Sail area: 500 sq. ft.
More info: Atom Voyages | Nicholson 31 Refit
Pacific Seacraft 31 - LOA: 31’10” LOD: 30’6” LWL: 24’2” Beam: 9’10” Draft: 4’/4’11” shoal option/standard full keel. Displacement: 11,000 lb. Ballast: 4,4000 lb. external lead. Sail area: 485 sq. ft. sloop, 600 cuter.
More info: Boats.com - Boat Review/Test: Cruising Expert
Pacific Seacraft : PS 31
Pacific Seacraft Mariah 31 - LOA: 36’ LOD: 31’ LWL: 25’ Beam: 10’9” Draft: 4’6” Displacement: 16,000 lb. Ballast: 6,000 lb. Sail area: 596 sq. ft.
More info: Mariah31 : Messages : 120-150 of 150
Southern Cross 31 - LOA: 34’6” LOD: 31’ LWL: 25’ Beam: 9’6” Draft: 4’6” Displacement: 13,600 lb. Ballast: 4,400 lb. internal lead.
More info: SCOA Home Page
Contessa 32 - LOD: 32’ LWL: 24’ Beam: 9’6” Draft: 5’6” Displacement: 9,500 lbs. Ballast: 4,500 lbs. internal lead.
More info: Sailing Magazine
Pearson Vanguard 32 - LOA: 32'6" LWL: 22'4" Beam: 9'3" Draft: 4'6" Displacement: 10,300 lbs. Ballast: 4,250 lbs. internal lead. Sail area: About 470 sq. ft.
More info: The venerable Pearson Vanguard This grand* old dame will* always be someone
pearson vanguard at pearsonvanguard.org
Rhodes Chesapeake 32 - LOA: 31'9" LWL: 22'1" Beam: 8'9" Draft: 4'9" Displacement: ? Ballast: 3,750 lbs. external lead. Sail area: 408 sq. ft. working sail and 588 with genoa.
More info: History
Westsail 32 - LOA: About 40' including bowsprit and boomkin. LOD: 32’ LWL: 27’6” Beam: 11’ Draft: 5’ Displacement: 19,500 Ballast: 7,000 lbs internal (lead/iron on early boats and all lead casting on later models). Sail area: 629 sq. ft.
More info: Westsail 32 - Wikipedia, the free encyclopedia
WOA Web Site
To this list, I'd add the following boats:
Hallberg Rassy Monsun 31
Elizabethan 29, 30, 31
Golden Hind 31
