You are getting ripped off on the USCG documentation IMHO... Yes, most lenders will require it, as it allows them to put a lien on the vessel more easily and makes their loan a bit more secure. That kind of loan is actually called a Marine Mortgage, since it is a secured loan.
I doubt your insurance is going to be only $840 a year, but I could be wrong—this is especially true if you want to go bluewater cruising in the boat. Given that you're looking at an IP32, rather than a Benehuntalina...you're probably not looking to stick to the coast.
Also, your slip fees sound low, since they're less than $3,000 per year. The repair and upgrade numbers are very low... since they're less than $3,500 annually, and this is a 17-year old boat we're talking about. You should figure on closer to $10,000 per year, at least initially....especially if you're planning on outfitting the boat for bluewater cruising.
