What new dinghy should I buy?
You actually CAN reef a stock Laser mainsail. I have done it, but not raced it. Because they are loose footed, you just wrap the luff around the mast. I wouldn''t do it to a good racing sail, but a working sail would be fine. you can reduce sail a lot, remove the top batten if you go farther than that on your wraps. You may need a longer outhaul line, but that would cost about ten bucks.
You can go out in pretty much anything then. Like I said, you wouldn''t race that way, because nobody else would be reefed. But just getting out there in a blow is fun.
