SailNet Community - View Single Post - last bit of water from the bilge
Old 10-18-2008
scosch scosch is offline
scosch is on a distinguished road
If one has two bilge pumps, a high volumn one that wouldnt have a check valve and a daily use smaller one that does have a valve, can the two drain hoses be Tee'd together somewhere to use the same thru hull? I guess they cant be teed until close to the thru hull and after the siphon loop or the water would drain back thru the check valveless pump.
