SailNet Community - View Single Post - last bit of water from the bilge
Old 10-18-2008
sailingdog sailingdog is offline
You generally don't want to have two bilge pumps hooked up to the same through-hull.
JRP's suggestion is a good one, where the small pump is considered a "maintenance" pump, and the larger one, with the high volume is a dewatering pump. Ideally, the larger pump should have a float switch located a few inches above the maintenance pump one and have a high-water alarm connect to the switch as well.
