SailNet Community - View Single Post - Four Days of Family Cruising on the Solent
post #19 of Old 10-19-2008
sailingdog
IF you're going to use it on a relatively small boat, I wouldn't go the DSLR route, since they're far more vulnerable to spray, salt, water, etc.... That said, for most people anything above the D40 is a bit overkill. That isn't just my opinion, but Ken Rockwell's as well. Unfortunately, the D40 has been replaced by the higher resolution, but not quite as good D40x.
BTW, most of the lenses you can use on the D40 will work on a later series DX-frame Nikon DSLR. However, some of the newest from Nikon are not DX-frame, but full-size sensor (35 mm) and as such will probably vingnette a bit with the DX-series lenses, as they are not designed to cover a full 35mm frame.
If you're going the DSLR route, a KATA camera cover might also be a good investment.
sailingdog is offline
