SailNet Community - View Single Post - steppng a mast on a 23 o'day pop top
post #7 of Old 10-20-2008
tommays
tommays's Avatar
As and example on a J24 with 34'6" mast
On a J24 we use a 19'+ gin pole setup on deck stablized in a tripod fashion with 2 cables going aft and one on the bow
For lifting gear we setup and old boom vang with 3:1 purshase to be able to make the lift buy hand
The J24 requires about 3' of lift to get the mast off the step and clear of the hull so it can be let down and layed flat
When you are putting one back up you need the FULL 19' of lift if you going to have the bridle anywere near the balance point of the mast
I would think with your cabin it may be more like 5' to get the mast clear of the hull
In general there is nothing fast about doing a keel steped mast
My home made pole is in two sections to keep the lenth down to 12' when it is in transport
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
