SailNet Community - View Single Post - boat sitting without bulkheads deformed?
post #2 of Old 10-25-2008
camaraderie
moderate?
camaraderie's Avatar
Welcome aboard! You should never say "all comments welcome" around here!
I'd frankly be more worried about the plywood core after 30 years. If the interior is wide open I think it would be relatively easy to design and fabricate appropriate bulkheads and glass them in place. Fibeglass is not going to take a permanent set, but it will easily flex or deform if not properly supported. Assuming the deck is on the boat and secured, I can't see missing the bulheads as being a significant structural issue.
That said. I am going to assume a couple of things I probably shouldn't and say: RUN FROM THIS PROJECT...it will cost you more in time, $$, and sweat than you will EVER be able to recoup.
camaraderie is offline
