SailNet Community - View Single Post - Engine Room Insulation
post #1 of Old 10-26-2008 Thread Starter
eharan
eharan's Avatar
Well, the engine is out, the compartment cleaned, painted and ready to for isulation. Now the choice. In my other boat, I installed the typical insulation that has a silver foil cover, with foam then lead then foam. It worked well for insultation/sound proofing but after a few years, the foil front fell off and created a mess.
On this boat, a Slocum 43, there were panels of insultation that look similar to something you'd buy in Home Depot. It had a solid perferated surface with some type of foam and then lead. It looked to be about 1" thick. It looks like it held up for 20 years so not to bad but it needed to be replaced for various reasons.
I am looking for a product that does not use the "foil", since this has proved unreliable over time, but uses a hard surface with the appropriate suspended barriers.
Any recommendations? There are a TON of products out there but the websites present inadequate desccriptions.
Ed
s/v Chotto I 43' Slocum
eharan is offline
