SailNet Community - View Single Post - Deck fill cap measurements
post #2 of Old 10-26-2008
JohnRPollard
Moderator
JohnRPollard's Avatar
Okapi3,
I'd like to help you, but our boat uses a bronze cap that is keyed to the winch handles.
You mention that you've tried all the usual remedies. In case you haven't tried it, I will suggest that you put a torch on the cap and heat it up. This will often break the bonds of corrosion.
One final suggestion -- If you are desperate to pump the holding tank, you can access it through the inspection port at the bottom of the starboard cockpit locker. (At least, you can on ours, and I do that about once a year to give it a good vacuuming with the pump out hose.)
JohnRPollard is offline
