Originally Posted by blt2ski
Can this be done and NOT hurt the structure/soundness of genoa/jib tracks, ie drill new holes for where my pin-stop carrs are? I got a new 155 the other day, and figured out the two holes that work, altho it would be nice to have holes at 1" increments tween the 4" holes from the factory.
I am hoping this will suffice until next year when funds are hopefully availible to install line control carrs.
Thanks
marty
Yep - did it on mine all good but You want to make sure that you do not drill through the "T"...(if you do that effects the structure). use one of those drill stoppers that keep the depth constant on the drill bit. Start them with a small bit, a medium and then the right size bit - as those tracks are pretty tough. Depth of the holes are pretty shallow but its a time consuming process...
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
