Getting a non-marine grade propane appliance for the boat strikes me as a bit foolhardy. The chances of being blown up or poisoned probably go up quite a bit with non-marine appliances, since pinholes from corrosion are probably much more a likelihood.
Originally Posted by sww914
On demand water heaters on ebay. About $200.00. They look exactly like the one I bought from Defender 10 years ago with a different label. They're not marine grade but they're cheap enough to replace every few years. IIRC I had to plumb a tee on the output for a pressure relief valve, it was $10-$20 at the hardware store.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
