SailNet Community - View Single Post - Foam vs. wool for buffing, waxing, etc.
post #9 of Old 10-28-2008
Maine Sail
Maine Sail's Avatar
While..
While a wax won't really hurt Awlgrip it won't help much. My main concern is this. Did you buff the Awlgrip too? If so you will now ALWAYS need to wax it. Awlgrip should never be compounded!!!! It cures like a clear coat / base coat system with the clear solids rising to the surface of the paint creating a hard, high shine shell. If you buff through this layer it's toast!!
Essentially the linear polyester resins can not be re-melted, what actually happens when you compound or buff a painted surface, because the window time of time between melt & disintegrate is so narrow. It is nearly impossible, and totally impossible for a novice who has not had serious specialty training or woring with LPU's, to keep an LPU at the right temp to re-melt without destroying it in the process. It sort of goes like this when buffing Awlgrip.
To cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, to cool, right temp for a split second, destroyed.......
Acrylic two part paints such as Imron can be buffed because the re-melt window is much wider and they don't cure the same as an LPU. The pigment on an acrylic LPU is the ful thickness not sitting under the clear solids..
This photo illustrates a destroyed Awlgrip finish. Note the shine on the majority of the hull even after many years. Now look at the center of the photo and you'll notice a large dull area. This is what happens when you chew through Awlgrips "protective shell". It is destroyed...
______
-Maine Sail / CS-36T
Maine Sail is offline
