SailNet Community - View Single Post - Collapsible Cradle
post #2 of Old 10-28-2008
sailingdog
Sure...
You could probably make the cradle using angle iron and 4"x4"s to create the cradle so that it can be easily disassembled.
You'll probably have to use some pipe in the construction of the cradle to put "boat stand" heads on to support the hulls and keep the boat balanced.
The real problem is keeping the pieces small enough to move and making the cradle light enough for you to move on your utility trailer. Steel angle iron heavy enough to make a cradle you can disassemble is going to be fairly heavy, probably a good deal heavier than a cradle that doesn't come apart.
sailingdog is offline
