This is all very interesting.
Out Hunter H28 had Origo non-pressurized twin burner stove and we liked it, fuel consumption was a bit of an issue, but we liked it very much.
Our Ticon has the Homestrand pressurized twin burner stove. It seems to heat quicker than the NP stove, uses less fuel and takes up less room.
Also, there are no requirements for propane sensors, lines and vented wells for tank storage.
We contemplated making the switch, (Admiral likes her tea, NOW) but after pricing it out we figured it would take a couple of decades to offset the conversion cost. Not too mention, we would have to find a place to build a vented well and run lines through tight quarters, cut up the counter-top and lose the gimbaled stove. We shall be rebuilding the Homestrand this winter.
Propane is actually a lot more dangerous ti use, if you don't believe me, go turn on the gas in your BBQ with the lid closed, come back in 1 min and light a match near the Q, talk to me after your eyebrows grow back.
It is true that a pressurized alcohol fire could be nasty, a propane explosion would be a lot worse.
Inexperienced operators are not allowed to touch anything (dangerous) on our boat, let alone gas fired appliances.
