Old 11-01-2008
kellysails kellysails is offline
kellysails is on a distinguished road
Great info Jack
Jack,
If one was to keep 12volt grounding system and counterpoise separated, how would you ground the negative side of 12 volt power to the radio set? I would assume that if you used the 12 volt grounding system for power it would end up bridged to the counterpoise system via the radio. But I assume that you need use the 12 volt ground in order to complete the circuit to the batteries.
Regards,
Craig
