SailNet Community - View Single Post - Winter boat safety?
post #3 of Old 11-01-2008
Sapperwhite
Not So Senior Member
Sapperwhite's Avatar
I lived aboard last winter. I kept a small space eater on all the time to keep it warm inside the cabin. I kept all seacocks closed except the cockpit drains. I kept fresh water for cooking and drinking, but showered in the marinas facility.
The only fresh water lines that I ever had problems with where the hot water lines that run through my engine compartment. It got colder in there with no warm air flowing in. Those lines stopped flowing a few times, but never burst. To correct it I just turned the water heater on for a little while and it would flow again.
Depending on if your water lines are routed through areas that will stay warm from your cabin heat or not, you may have problems with them freezing.
When I used any water (cooking, cleaning, teeth brushing, etc) i would open the sink drain seacock, let it drain, the close it back off immediately so i didn't forget it.
I wintertized the engine, that's a must do. It gets cold in the engine room. Unless you install a small heater in there, and even if you do, winterize the engine. If the engine freezes it'll be big bucks to fix.
Dictated, but not read.
Sapperwhite is offline
