A prudent mariner would leak check their propane system every time they use it... I do... There's a pressure gauge by the regulator and what you do is open the propane tank to pressurize the lines...and then close the valve... look at the pressure gauge, and see what it says... in five minutes come back and look at it again.... if there is a significant difference, that indicates you've got a leak someplace.
