water in boat
I would wonder where the water is coming in too. But, if the boat has been left alone for long periods of time, likely the water is from rain, finding it''s way into the boat (around a leaky fitting or hatch) and draining into the bilge. Doesn''t sound like much. If it was a real leak, there would be evidence of how high the water is getting before the bilge pump kick on. It has been my experience that the float switches tend to be unreliable. Point is, If you don''t see that the bilge has a scum line in it and it looks like a lot of water is cycling through and the pump is taking it away, it is most likely just rain water, not a hull leak.
Hope that helps!
Paul
