SailNet Community - View Single Post - what mast?
Thread: what mast?
Old 03-13-2004
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
what mast?
Properly designed a deck stepped mast can work quite well in most applications. I personally strongly prefer a deck-stepped mast over a keel stepped mast but once again this is an area where opinions can differ widely. There is no right answer here. There is a contingent that thinks that the only proper way to step a mast is on the keel. There is a logic to that but it is a logic that can be engineered around and which comes out of a historical context that is less relevant with modern materials and rig design.
To start with the basics, the base of a mast has a vertical and horizontal thrust to it that tries to push it down through the bottom of the boat and also sideward off of the mast step. In normal conditions the down load is several times greater than the side load. Beyond the loads imparted to the boat, there is also the issue of the loads that happen internally in a mast. When you look at the structure of a mast it is really a truss standing on end but it does not completely act as truss because the components of a truss are not supposed to have bending loads on them. Ideally the loads in the mast are primarily axial (acting along the length of the mast) rather than in bending (acting perpendicular to the long axis of the mast). Of course masts do have fairly large bending loads imparted into them. The two most often cited reasons for keel stepped masts being considered stronger is the way that the bending loads (moments) are distributed within the mast itself and the way that the mast imparts its loads into the boat.
If the goal of designing a mast is to reduce bending moments within a mast, the greater the number of panels (segments between shrouds and other supports) the smaller the moments tend to be. In the days when single spreader rigs were most common a keel-stepped mast added one extra panel, the segment between the mast partners at the deck and the keel. This has become less significant as bigger boats have routinely gone to multiple spreader rigs and moment connections at the deck mounted mast steps.
In terms of the way that the mast imparts its loads into the boat, masts are generally located in the area of the cabin trunk and because of the shape of the cabin (i.e. the deck folds up at the cabin side and horizontal again at the coach roof) this area, if not engineered for side loads is more prone to lateral flexing than would be the keel. One idea behind a keel-stepped mast being stronger is that with a keel stepped the mast is not supposed loads are put loads into the deck.
In reality, this ideal is rarely accomplished for a number of reasons. First of all, if the mast is not tied to the deck or the deck tied to the keel near the mast, either with a tie rod or a tie from the mast to the deck and a connection from the mast to the keel, the downward force of the mast working in opposition to the upward loads of the shrouds can pull the hull together like a bow and arrow lifting the deck and separating the joint between bulkheads and the deck. You sometimes see this type of separated bulkheads on inexpensive or early fiberglass boats with keel stepped masts.
Not only do keel stepped masts impart vertical loads into the deck (through the ties mentioned above) but they also typically end up imparting side loads as well (if they are going to reduce the moments in the mast as mentioned above). This somewhat reduces the structural advantages of a keel-stepped mast to next to zero assuming that a deck-stepped mast is properly engineered, and that is a big if!
There are several things that I consider critical to engineering a deck stepped mast properly. Primary is having a jack post below the mast. A jack post is a vertical member that carries the vertical loads of the mast to the keel. My preference is to have an aluminum jack post rather than a wooden one but a wooden post can work as well. The other issue is the distribution of the side loads. Ideally there should be a bulkhead or ring frame adjacent to the mast that can take the side loads and distribute them into the hull. These are obviously more complex to do than simply having a fat spot on the keel for the mast step to land on.
My objections are to the purely practical. Keel stepped masts mean that there is always water in the bilge. This water comes in at halyard boxes and other openings in the mast and nothing you can do will stop that. Second, it is way harder to step and unstep a keel-stepped mast making the boat more subject to damage in the process. Beyond that if you loose a mast (I have lost two in my life) it is better in my opinion to loose a deck stepped mast because a keel-stepped mast is more likely to damage the deck when it fails and a deck-stepped mast is easier to clear away. The keel stepped mast advocates point out that you are more likely to end up with a bigger stump after the mast fails. I am not sure that that is the case if you are able to tow the rig as a drougue until things quiet down enough to rig a jurry rig. I am not sure what you do when the boat is being beaten to death by the upper portion of a mast that has buckled 20 feet off the deck at the spreaders. .
My preferred set up is a deck stepped mast that has a welded flange on its bottom that is through bolted through the deck into the top flange of a structural aluminum jack post. My new boat has a keel stepped mast. It is my intent to pull this mast and have it modified to that arrangement if I ever go offshore with her.
Respectfully,
