SailNet Community - View Single Post - how much foam in a Mac or Venture 25?
post #11 of Old 11-03-2008
artbyjody
artbyjody's Avatar
Originally Posted by EdWarren View Post
I have sailed for over 40 years, open ocean and currently sail midwest lakes. I have a very low opinion on the value of 'floatation foam'. I think it does a lot more to sell boats than to save boats. If it is there, good, leave it, there is no real imperative to remove it. If not theer,that's ok also. Because of the marketing, the novice is lead to believe this is a major safety item.
Actually - the Coast Guard has manufacture / boat building regulations that require usage of flotation foam that must be used depending on design criteria, floatability etc....
Source: http://files.dnr.state.mn.us/educati...atbuilders.pdf
That particular regulation guide is a "easier to understand" version than what actual manufactures have to adhere to.
So - its really not a "marketing spin" per se - but if one has to do it, may as well use whatever marketing points you can get out of it. That document may help to OP calculate how much foam is actually required.
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
