Thread: AC Bilge Pumps?
Old 11-03-2008
sailingdog sailingdog is offline
I'd second trying to reduce the inflow as much as possible, by fixing whatever is leaking. Seems to me that a boat should keep the water out... at least as much as is possible. Also, relying on AC-based pumps seems a bit foolish, since the times when the AC cuts out—storms and the like, are probably when you're most likely to need the pumps most.
