SailNet Community - View Single Post - how much foam in a Mac or Venture 25?
post #14 of Old 11-03-2008
N0NJY
N0NJY's Avatar
Here's another little interesting thing. This boat (mine) was built in 1979. Apparently there were no "standards" then?
The manual says:
POLYSTYRENE (Styrofoam for example) is the least expensive foam available, but it
will dissolve upon contact with gasoline, is brittle and will crumble when left exposed to
sunlight. Builders who choose to use Polystyrene foams should cover them with
plywood, vinyl or another material, or enclose the foam in compartments where it is not
exposed to abrasion, the elements or sunlight. Polystyrene should not be installed
near the engine or bilges.
This stuff is polystyrene and is not covered by anything. in fact, the rear hold has the gas tanks stored there (on my boat) so, it bugs me this stuff is even there.
Rick Donaldson, NØNJY
moˈloːn laˈbe!
It's better to be hated for who you are, than to be loved for who you're not.
Let those winds of change blow over my head,
I'd rather die while I'm living than live while I'm dead - Jimmy Buffet
N0NJY is offline
