SailNet Community - View Single Post - nmea output from Raymarine Graphic
  #15 (permalink)
Old 11-03-2008
j34035's Avatar
j34035 j34035 is offline
"Sparkie"
j34035 is on a distinguished road
SD,
You may well be correct. The information is in the Graphic, as I can see magnetic headings displayed, but there may be some issue with the way the system is constructed or configured that keeps it from sending the data. It may be that I have to bite the bullet and spend money to make it work, but it is frustrating to see part of the data I need transmitted and not be able to see the rest. I also have my Garmin GPS inputting position data through the NMEA input connector. All that data displays correctly, but it will not repeat that data out through the output connector. I did not expect it to output that data as that was not a listed function in the output table. I did post to Ray and got a reply. They told me the graphic was not a full seatalk converter but I need to find out what is missing to make it function with the six sentences THEY say will work. Otherwise, I will have to buy the converter. Right now everything I need from the GPS I can bring in through the USB and read using a virtual com port, and the rest I was hoping to get through my COM 1 serial port. Stuff like this is actually fun to figure out, but can be frustrating. Thanks again for your help....
DD
Doug
Jboat J/37c (new to me Jan 2011)
