SailNet Community - View Single Post - Using a portable battery charger onboard
post #6 of Old 11-04-2008
sailingdog
Sander-
An older style battery charger will not have bulk, absorption and float stages... and as such will generally run at a higher voltage than the battery requires when it is nearly fully charged... and doing so generates excess heat and boils off electrolyte in the case of wet-cells, and just fries the gel in gel cells and AGMs.. If he leaves an old-style battery charger connected for any significant period of time... which is necessary to get the batteries up to 100%, he runs a much higher risk of frying them if it isn't a smart charger.
sailingdog is offline
