SailNet Community - View Single Post - Diesel Blues
Thread: Diesel Blues
post #3 of Old 03-22-2004
RichH
RichH's Avatar
Diesel Blues
Symptoms are suggestive of an air leak in the fuel system piping. Boat fuel piping when ''compression'' fittings are applied are very subject to ingress of air; solution: (if thats the problem) is to install/replace with flared fittings. Older fuel oil filter sets used neoprene/BUNA rubber seals, modern filter sets now use EPDM (ethylenepropylenediaminemonomer) which dont ''age'' as badly as neoprene/BUNA. Carefully inspect the seals on the Racors, etc. for aging seals.
A visual inspection of the tank internals will quickly show if the need for cleaning is waranted. Cleaning is best performed by mechanical scrubbing the internals, followed by a high pressure wash with detergent, etc. If you have a thick ''black'' coating on the surface walls of the tankage that would indicated polymerization of old fuel, if ''slimey'' would indicate a bacterial infection. Actual cleaning is usually the best remedy. However, for future attenuation of ''particles'' you can apply an onboard recirculation/polishing system consisting of a dip tube to the very bottom of the tank, a 20ÁM ''depth'' filter, followed by a 12v transfer pump (wired to the engine panel) and a delivery tube back to the tank. The 15-20uM filter set is run any time the engine is on and will keep the resident particles to a ''sub-micronic'' level (due to % (wt.) removal of such particles at each ''pass''. For a bombproof system consider to apply an independent 2-3 gallon gravity feed ''day'' tank between the Racors and the engine ... so that if you have any ''problems'' you can switch to the day tank run for about 3 hours and ''sort the problem later. If you want the schematic of my system, email me direct. (I''m very deeply involved in filtration engineering.)
RichH is offline
