Good compression on an A4 is between 90 and 115. Your head may have a borderline gasket or undertorqued studs (there is a Seacraft manual with the torquing order). "Wet" is ambiguous: An A4 can suck water back into the manifold (wetting the plugs!) if the waterlift muffler is failing or the water supply isn't vented or there is sufficient crud in the exhaust to create back pressure. A 30 year old exhaust is due for a replacement. I have done this and solved a horde of issues thereby.
As noted above, you could have multiple issues there...or just old plugs.
A rich mixture and timing would be my first suspects, as well. Running a tach check (700 RPM is a good idle speed) is helpful. It wouldn't hurt to replace the spark plug wires, either, if they are original.
After you eliminate or adjust timing and mix, consider switching from the recommended Champion RJ-8Cs plugs gapped to .035 to RJ-12C plugs gapped to .040. You'll get a stronger spark and a cleaner burn. My starts have improved quite a bit since I made this a habit, and it's a tip I got from the venerable Atomic 4 Usenet listserv.
