Old 11-10-2008
Bene505's Avatar
Bene505 Bene505 is offline
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
The tubes are 2" in diameter. it is aluminum, not SS. However, I went with polished aluminum to make it look like stainless to match the rest of the boat. THe reason for this is it allows less weight aloft (88 lbs total, IIRC), is easier to tap (as I also use the arch for other things), and it is less expensive than SS. To get a 2" arch out of stainless, you will have a VERY heavy unit and very expensive. The reason I like the 2" diamters is for easy, multiple wire runs for multiple components.
On average, I get approximately 205-210ah/day from the units. Somtimes more, sometimes less.
- CD
CD,
Great post, coinsidering I need to build something to support my Fourwinds wind generator. There's one aspect of this that I'm wondering about.
Would you still need 2" diameter if you went with Stainless, or would you pick up some strength from the different material? (Perhaps that would allowing you to go to 1.5 inches.)
Also, how long does the polished aluminum last? In 15 years what does it look like?
