Thread: Beneteau 423
Old 03-25-2004
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
Jeff_H will become famous soon enoughJeff_H will become famous soon enough
Beneteau 423
Maybe this is just me but I need to ask, out of curiousity, if nothing else, if you are planning on sailing around the world, how did you decide that a Beneteau 423 would be the right boat?
As much as I like Beneteaus for coastal cruising and even think this would be a reasonable boat for a Carribean sojourn, I would think that there are much better choices than a Beneteau 423 for that purpose. When you think of doing a circumnavigation you are talking about a lot of sea miles in a very wide range of conditions. A circumnavigation is roughly equivilent to the amount of miles that an average coastal cruiser does in 20 to 20 years of sailing only in harher conditions and further from repair yards. That is a lot of wear and tear. You need a boat that is robust enough take that kind of abuse and frankly, with all due respect to the Beneteau 423, they are just not that robust.
As to your question, if you do have your heart set on a circumnavigation on a Beneteau 423, then I would suggest going with the standard 5''7" draft version which should be a reasonable balance between seaworthiness and shallow enough draft to get into most popular cruising locations.
Respectfully,
