SailNet Community - View Single Post - Outboard Mount and the transom of a Cal 20
Old 11-12-2008
Calabego's Avatar
Calabego Calabego is offline
45.63N 122.67W
Calabego is on a distinguished road
My cal has the same transom mount and does flex a little with the weight of the OB. You can crawl past the quarter berth and gain access to the transom for this task. I'd also tighten all the nuts for the various deck fittings while you're back there. A 1.5x1.5' square piece of marine ply backed by fender style washers might be overkill, but they'll distribute the weight of the motor under power or while hanging out of the water to reduce the flex of the glass. Mine has been operated for at least a decade with the motor hanging from the transom with no issues.
Signature picture courtesy of Cal20 Class Assn.
