Need advice on non skid paint
From WEST System “Epoxyworks 22" (Winter 2004)
http://westsystem.com/ewmag/
“REPAIR MOLDED NON-SKID and GET PROFESSIONAL RESULTS”
By Tom Pawlak
“If the patterned non-skid on your production-built fiberglass boat needs repair, you may be interested to know flexible molds are available for making professional looking repairs. Gibco Flex-Mold™ produces the non-skid patterns used to mold the non-skid on fiberglass boat molds. They also produce flexible molds designed for repairing existing non-skid patterns used on hundreds of production fiberglass and one-off boats. You can call them to see if they have the pattern you are looking for. If the damage to the deck is more than cosmetic, repair it prior to continuing. Refer to the procedures for structural repair as described in our 002-550 Fiberglass Boat Repair & Maintenance manual.
The Flex-Mold is designed to lock into the existing molded pattern on your boat and works best if the pattern has not been painted over. If paint has been applied or if debris has accumulated in the pattern, the fit will be poor at best and the repair will be harder to blend in. Mold release is applied to the Flex-Mold at the factory so epoxy or the polyester gelcoat used to make the repair will not stick to it.
Apply mold release wax to existing non-skid prior to beginning the actual repair. Spread wax well beyond the actual repair because gelcoat will migrate. Use wipe on/wipe off method to apply wax.
Use a router to remove the damaged non-skid. Remove only the thickness of the pattern, no more. If you grind through the opaque white gelcoat or you can see the dark substrate through it, you must then fill the dark low spots with gelcoat so that after molding a new non-skid you do not see the dark laminate through the thinnest, lowest parts of the gelcoat pattern.
If the damage went beyond the base gelcoat thickness, or you are finishing a structural repair, you will have to router a void to fill with a thick enough layer of gelcoat to make an opaque base for the pattern. This layer of gelcoat is then machined with a shallower pass on the router, to level the opaque layer and establish the base of the non-skid pattern. Break the corner of the routed area with sandpaper.
Position the Flex-Mold over the area to be repaired, moving it around until it locks onto the pattern. Tape one end down securely and roll back the Flex-Mold until the repair area is accessible.
Pour catalyzed gelcoat (you can use epoxy but it will require painting) near the Flex-Mold.
Slowly flex the mold forward while continuously engaging the non-skid pattern. Use a stiff rubber or plastic spreader to uniformly apply pressure to the backside of the Flex-Mold, effectively squeezing out the excess gelcoat. Allow the gelcoat to cure before removing the mold. Clean up excess gelcoat film (surrounding the repair) with an air nozzle or by brushing the area with a stiff bristled brush. When done correctly, the repair will not be detectable.
If you are interested in doing your own non-skid repairs, contact Gibco Flex-Mold at 817-236-5021 or gibco@swbell.net”
Epoxyworks 22 / Winter 2004
