SailNet Community - View Single Post - Shore Power and Batteries
post #5 of Old 11-13-2008
sailingdog
A good list Bill.
Originally Posted by btrayfors View Post
As best I'm able to discern, through formal testing and thru personal experience, for boats at dockside much/most of the time I believe it's best to:
1. use a smart battery charger only, and preferably one which uses pulse width modulation (PWM) technology...like the Iotas;
2. leave the charger on all the time (assuming that you have reliable dock power and that you have a properly installed AC system and battery charger);
3. equalize the batteries at intervals recommended by the manufacturer. Note that the PWM chargers like the Iota MAY reduce the need for equalization;
4. exercise the batteries periodically, drawing them down to not more than 50% of capacity and then fully recharging them;
5. use ONLY distilled water to be sure the electrolyte is at least 3/8" above the plates;
6. use Hydrocaps or WaterMiser caps to reduce the need for adding water;
7. keep all connections very clean and tight;
8. be extremely careful not to introduce contaminants into the battery cells; and
9. monitor battery voltage periodically, with and without charging and load.
Sound like a lot of work? Not really, just a little attention on a regular basis.
Bill
sailingdog is offline
