SailNet Community - View Single Post - More Zinc Please...
post #10 of Old 11-13-2008
sailingdog
Originally Posted by jbondy View Post
Dog, Thanks. I too have this problem and will find this helpful. Three questions:
1. I have a memory circuit for the stereo, which is switched so I can stop the battery drain during long periods of non-use. I'll switch it off before doing the leak test. I know this isn't a "leak", but does this minimal powered ciircuit contribute to the zinc corrosion?
If there isn't a ground leak to the water...then it shouldn't matter. BTW, I would highly recommend that you physically disconnect all the wires for the DC ground leak testing...
2. I have a bilge pump with a float switch. As long as it's not actively pumping, this shouldn't affect the leak test, should it? In your preliminary diagnosis test, I assume you are referring to bilge pumps with electronic switches that draw current as part of the sense circuitry. A float switched bilge pump shouldn't have to be disabled before the leak test, correct?
see above.
3. Your instructions tell how deterine if you have a leak. How do you isolate it if you determine you have one?
TIA
I don't give instructions for isolating or fixing a DC ground leak, because they're very specific to each individual case.
sailingdog is offline
